Originally Posted by tamagucci
Hi all, I just recently lifted my '07 v6 using Bilstein 5100s in conjunction with OME 884s in the front and Toytec superflex coils in the rear. It gave me almost 3 inches of lift!
I want to purchase 17' wheels but am unsure with all the different size options. I was hoping the wheels would have a little wider stance than stock to make up for the rise in center of gravity. (without using wheel spacers)
of these two options (or if you have other suggestions I am open) which would be "further out" and also not rub? I don't want to cut anything.
17x8.5 6x5.5, 0 offset, 4.75 backspace
17 X 8.56 X 139.7, -10mm offset, 4.30 backspace
Also tire suggestions would help immensely.
I have been doing research but it's kind of an emergency because one of my tires is leaky and I really don't want to buy another 18" tire if I can help it.
I would have started a separate thread, but I only have one active post, my apologies.
I don't have an opinion on the backspacing questions but got pics of the new setup? I'm looking at the same configuration. Also tire-wise, been running Falken Wildpeaks with zero regrets.
