If you run the factory enclosure, buy the JL or Rockford 8". The enclosure volume was something like .43ft3. Minus sub displacement, looking at .39-.4ft3. I had modeled a few different 8" subs in winisd and the JL and RF modeled the best. Pump 250w rms to these and call it a day.
You may not even need a t-harness that tacotunes sells. If your amp takes high level inputs, just tap the front speaker wires, and ignition signal, run those to amp. Power and ground and call it a day. These are subs, not much to it.
