Originally Posted by steelevo
I agree that road force balancing is a must with a lot of tires.
Also, since you have a different set of wheels, I would double check the hub bore. If it’s not to exact OEM spec, you’ll need a hub centric ring to fill the gap. You’d be surprised at this not centering the wheel perfectly.
The wheels were designed specifically for the 4runner and tacoma. Everything was fine prior to the first rotation.
My discount tire has a machine that says road force balancing, and that's what they used to balance my tires. Not sure if there's anything additional on top of that thats needed.
