Originally Posted by Devbot
Hey, just tried to tackle this yesterday.
Personally my trouble started with a combination of P0171/P0325/P0420. Initially suspected a vacuum leak and couldn't find one, so decided to replace the MAF and that took out P0171 and P0420, but P0325 still persisted. When cleared, the CEL will turn off until a steep grade or other means of heavy acceleration.
I read about splicing the two sensors together to trick the ECU around the code and that this worked for many people - thinking this would be the best step since it was the least amount of work and money, I gave it a shot but to no avail. CEL still on.
Next weekend I'm just going to replace the sensors and harness together and call it good; you might as well if you have to open everything up just to service either one. Knock sensors are a headache that will NOT go away like other codes.
(car is a 2000 SR5 at 282k)
I feel ya. It's a stubborn code that's a lot of work and money to fix and becoming more frequent. I fear this code is going to put a lot of 4Runners out of commission due to the high repair costs vs value of the vehicle.
