Originally Posted by Frodaddy
Bilstein Heavy Load (400lb) #36-281831 would work great on your type of setup, but they provide only 1.5" lift. You could run a small spacer with these to get to 2" if that is the height you really want to achieve.
OME Options:
889 - 2.5 - 3" lift - Medium Rear Coils
898 - 2.5 - 3" lift - Heavy Load - 440 lbs constant load
899 - 2.5-3" lift - Heavy Load - 880 lbs constant load
All OME's are 2.5-3" Lift which may be a little tall for what your wanting to do. Either way, I would stick around the 400lb added load rating.
Both the Bilstein's and the OME's are linear, which I prefer.
He might get more lift. I have same springs and had 2.5” of lift over weighted OEMs. Above load minus bike and rack
Before Hub center to fender
-driver 20”
-passenger 19.5
Afterward hub center to fender
Driver 22.5
Passenger 22.5
