I have an 05 SR5 with about 140k. My liftgate also just stopped working suddenly. This is the only post I found with the same symptoms. Every other post I found had a stuck/rusted actuator or ALL the electrical in the rear was out(window, wiper, etc) or the actuator would try to work. I have no noise from the actuator and everything else works (window, wiper). Ordered a new actuator for $200 but still doesn't work. I didn't install it, just plugged it in to test first. Now I'm assuming the switch is bad, not the actuator, but is there something I need to do to reset the new actuator? I don't want to order more parts or do more work if this is the solution and I just missed something. Also I was curious if the driver door button and FOB control the switch, not the actuator directly.
