Originally Posted by Bumbo
It is a tight fit but not too bad, make sure you get your terminal orientation right. You want the positive towards the engine.
I did mine years ago, and it's been great, but I have plans to tear it all out and upgrade various items because I can't leave good enough alone.
Existing:
Dirty Parts Tray
Blue Sea ACR
Blue Sea Fuse Blocks (engine bay and interior sub panel)
Blue Sea Low Voltage Disconnect
Cut and crimped cables to length
Genasun MPPT Solar Charge Controller
Bunch of Anderson Quick Disconnects
Bunch of other add-on and accessories
I did a write up on the ACR here:
Blue Sea ACR - Automatic Charging Relays
I originally bought the 7610 but later changed to 7611.
Upgrade:
Relocate battery and upgrade to a compact lithium setup.
Delete traditional fuse block for Switch Pro 9100
Delete ACR for a DC-DC charger - Victron Energy
Delete Genasun MPPT for Victron MPPT for monitoring and reporting capability.
If all that provides me with enough room where the old battery went, I will install 100% duty cycle compressor from Hummer central air system.
Looks good, I appreciate your information, thank you for sharing! When you relocate your battery, where are you moving it to? Which new battery are you looking at? Since you’ve been through this I’d like to consider your changes you’re planning on implementing. Seems like it’s a little bigger job and more parts than I was initially anticipating but like the additional and failsafes and like to do it right the first time.
I put a second battery in a truck years ago but all I did was run it in series and had enough room in the engine bay to butt it up against the original. Worked fine for what I needed it for.
My build thread https://www.toyota-4runner.org/4th-g...ml#post3520544
2008 Titanium Metallic 4WD 4Runner V6 SR5| Satoshi Grille mod|17x8 Level 8 MK6 wheels, 275/70/17" Falken Wildpeak tires| Front-Bilstein 5100's set at 0 with ToyTec branded Eibach silver springs and 1/2" ToyTec spacer driver side, 1/4" ToyTec spacer passenger|Front Diff. drop spacer kit|sway bar relocate kit| Rear-Fox 2.0Resi and ToyTec superflex black springs|Tyger Bull bar with LED's/Lund HX tube side steps
2021 Subaru Crosstrek Limited in Crystal White Pearl
