Any plans with that 2.2 pulley?
Originally Posted by Formidable
Got the URD AIC running properly today. Up until now it was not seeing boost and only adjusting timing. After a bunch of swear words and blowing into the line to test it’s integrity I finally found the culprit. It was a defective T connector that was blocked on one end... Anyway, drilled out the blocked T connector, reconnected the boost line and started tuning. Got rid of the high gear low rpm ping and the ping at 4500 rpm with pulling timing earlier, (or “adding retard” the politically incorrect way to say it). Added some fuel and upgraded to 2.1” pulley today.
Pulls great. No ping whatsoever. Drivability is awesome. Gadget at URD did a great job on the AIC. Very happy with this mod. Now I need a wide band O2 sensor to dial in the fuel.
