Originally Posted by TRDHULK
I basically have a "no questions asked" bumper to bumper 125k mile warranty, so if something happens its not a problem.
I've done all of this in under 3k miles, so I'm sure I'll eventually upgrade the shocks, struts and coils ones day; most likely long before I experience any issues.
I dont feel I'll need to yet, but I've only driven about 35 miles with the new tires.
In my experience you'll end up wanting a re-gear. 34's were what pushed me over the edge to do it. It's considerably better off road, otherwise you'll be feathering the gas and break all the time. On road performance wise acceleration improves as well. I get 15.5 mpg on a mix of street and highway FWIW
As far as rubbing goes that looks good sitting still but it'll rub if you compress it. You'll need to trim your fender liners and maybe hammer flat or trim your pinch welds. If you can push your caster out any further I would consider that too Definitely ditch the spacers
