No, the front doors are just a little different. Instead of going into to remove the both bolts from inside of door you do one from edge of door, otherwise they are the same. On the edge of the door you will see a small black grommet. Once you remove that (do not damage it as you will need to replace it), you will see the head of the bolt right there.
I just replaced all 4 door handles on my 2012 and it was very easy. I've had the door panels off many times so I can get them off and back on in a matter of minutes so this job was quick for me.
