View Single Post
Old 04-28-2020, 01:57 PM
midcoma midcoma is offline
midcoma has a spectacular aura about midcoma has a spectacular aura about midcoma has a spectacular aura about
Originally Posted by Blackdawg View Post
Have you tried it on a 1st gen tacoma yet? Id be interested in a kit with ebrake.
This kit will fit a 1st Gen Tacoma axle. Does your Tacoma have ABS?
The parking brake assembly will work also, but it's a bit different for a Tacoma. I have it set up on my 1st Gen Tacoma using a 4Runner parking brake handle mounted between the seats. PM me and we can discuss it more.
Originally Posted by rideexileex View Post
REAR DISC BRAKES REQUIRE A PROPORTIONING VALVE!!!
People are going to get in bad accidents without a properly adjusted rear brake system... This should be a required part of the kit IMO.
I don't disagree with you; however, I'd love to hear what you have to say about running a proportioning valve on an ABS set-up.
My thought is that the ABS gets it's input from the axle shaft rotation and makes adjustments from there. Rear disc brakes don't change how the ABS system gets its input from the rear axle shaft. In my mind, the system will function as designed.
On my 4Runner, I deleted the ABS system and I do run a manual proportioning valve. But I don't think a proportioning valve is a required item for a kit designed to work with ABS.
midcoma is offline   Reply With QuoteReply With Quote
