View Single Post
Old 04-28-2020, 05:00 PM
ACE115 ACE115 is offline
ACE115 is on a distinguished road
Sign me up for a kit with an E-Brake set up as well please.
Originally Posted by midcoma View Post
This kit will fit a 1st Gen Tacoma axle. Does your Tacoma have ABS? If it does, these brackets will fit fine, if not, I can make brackets without the ABS cut-out. Take a look at the picture of the brackets laid out in the back of my 4Runner. The sets on the right are for non-ABS axle housings.
The parking brake assembly will work also, but it's a bit different for a Tacoma. I have it set up on my 1st Gen Tacoma using a 4Runner parking brake handle mounted between the seats. PM me and we can discuss it more.
I don't disagree with you; however, I'd love to hear what you have to say about running a proportioning valve on an ABS set-up.
My thought is that the ABS gets it's input from the axle shaft rotation and makes adjustments from there. Rear disc brakes don't change how the ABS system gets its input from the rear axle shaft. In my mind, the system will function as designed.
On my 4Runner, I deleted the ABS system and I do run a manual proportioning valve. But I don't think a proportioning valve is a required item for a kit designed to work with ABS.
ACE115 is offline   Reply With QuoteReply With Quote
