Originally Posted by gamefreakgc
Do you feel the vibration in the steering wheel or the body (your chair)? If it's felt in the steering wheel it's the fronts, probably has pad print on it or brake residue buildup.
If you are feeling it in the body of the vehicle the rear drums need a good looking at. When the drum brakes are replaced the springs are also supposed to be changed, they might have been re-used. You might have to turn the drums too, any warping is hard to see by just looking at them.
It’s definitely in the chair and more rear body the back end shakes. Very annoying! I will look into the replacing the drum springs and turn the drums.
