Help with installing Toytec Boss Aluma 2.0 on KDSS 4Runner
Today I attempted the install of my lift, but I had to give up. Before I completely throw in the towel and pay for the install, I wanted to see if anyone had any insight for me. I removed the upper control arms, I opened up the KDSS shutter valves, I removed the front sway bar at the KDSS piston and hard mount, and I removed the bolts from the lower control arm ball joints. I was able to get the boss Aluma 2.0 driver side strut assembly in place, but the bottom bolt hole was way too low, and I could not get the lower control arm to go any lower. Any ideas to either compress the strut assembly or lower the lower control arm a little further? I did try compressing the spring, but it didn't seem to compress the whole strut assembly.
Thanks
Sent from my Pixel 2 using Tapatalk
