Originally Posted by montijo505
The clearance is pretty insane, however if I had a front sway bar at the time it would have been hard to make it work because its tucked so high to the diff and everything. I dont know whether they changed the design for that.
It doesn't require a ton of welding, I'm a novice and was able to get it done. Hardest part is the fit up. You have to install portions, tack, remove and finish weld to make sure everything lines up.
Sent from my SM-G986U using Tapatalk
Oof, so for the fit up you are tack welding on your back under your car?
I love Coastal Offroad's designs but I'm always afraid its beyond my skill set.
