Originally Posted by cranknostart
Got the timing belt on and everything put together.
The Engine started, however it has a very ticking noise.
Video of ticking noise: YouTube
3 DTCs now appear:
P0300
P0304
P0308.
Swapped the Coil Packs and Spark plugs from working cylinder to non working, nothing changed.
Cleaned MAF, no change.
Anyone have any ideas for me to try next?
How likely is it the timing slips and damaged the motor?
Do a compression test on cylinders 4 and 8, if the compression is off you most likely damaged valves when it jumped timing.
