View Single Post
Old 05-10-2020, 11:51 PM
Muff Muff's Avatar
Muff Muff Muff Muff is offline
Muff Muff will become famous soon enough
Muff Muff's Avatar
Originally Posted by Bumbo View Post
I would kick myself for not doing the differential if I going to open for gearing.
That said, if you don't plan on crawling and getting a tire off ground, it's going to be of little use to you and a waste of cash.
There are other types of traction devices to consider... if I didn't have wheels leaving the ground on the regular basis, I would look into something like a mechanical limited slip. (Torsen style / Detroid trutrac)
  • No maintenance when compared to a clutch based system
  • It's always "on" and working (unlike a selectable locker)
  • Works on and off/road
  • Provides more traction and benefit for your use case.
  • Seems like it would compliment ATRAC for the tougher situations where you might be doing some light crawling.
Yes and no. LSDs are certainly better than open differentials, but both clutch type and Torsens will behave identically to an open differential if a wheel is off the ground.
OP: If you don't see yourself needing a locker for the type of off roading you do, you should probably save your money and just leave the open diffs in there.
Muff Muff is offline   Reply With QuoteReply With Quote
