Originally Posted by Bumbo
ARB air solenoids are still electric... you can wire them up to an spod or switch pro without issues.
The user experience for both is pretty much the same once it's installed. That said, you will use one additional circuit for the compressor assuming you have a dedicated one and not just using OBA.
I agree with you on user experience and the maintenance aspect. If air lines break they are easy, cheap, and quick to repair assuming you the right tools on the trail.
I already have my compressor wired to spod as well as I had space available but will most be likely adding a second one soon as this stuff never ends.
