Originally Posted by calimobber
I dont think you can go much higher but you can go a little wider. It sticks out toward the engine with nothing under it. I bet you could just make a metal sheet and bolt it down so it supports the battery still.
I have 80w solar panel on the roof so that helps boost the battery back up when the suns out.
I also have the CS144. I used to have 2 optima yellows. I still have the battery tray I welded mounted if I want to run a second again. It was in the back left corner of the engine bay.
I had my 100w panel on mine when I went on my 5 month road trip. Where did you tie yours in at? I used the aux power outlet in back but at the relay it was only getting 7v.
Oh so you dont have the ABS setup in the way. I need to remove that so I can have a better battery setup.
