View Single Post
Old 05-14-2020, 06:48 PM
sage2050 sage2050 is offline
sage2050 is on a distinguished road
Originally Posted by Toy2play View Post
I cant think of any other reason why your transmission quit work at the exact same time your radiator blew other than the fluids mixed. Before this all happened, did you notice any shifting issues, higher engine temps? Pull the radiator cap off and also look in your overflow tank to see if you see any oily consistency. Does the 4runner start up and idle fine?
temp went above the mid line after the loss of power, because the radiator was dumping coolant. no problems before that. Car was running perfectly smooth right up until this.
pic of transmission dip stick with a drop of fluid on the ground next to it to see the consistency (oily, not thick). Fluid low, but car wasn't showing any "no fluid" signs.
also a pic of the radiator crack and the blown off epoxy. theory here is the crack extended to the left past the patch and the pressure differential started pushing hot fluid out which melted the epoxy and caused the blowout.
sage2050 is offline   Reply With QuoteReply With Quote
