Start with a new radiator, top off the trans fluid, and see where you are at. It's entirely possible you are too low on trans fluid. Anything close to the bottom line there will cause issues. What do you feel when you shift from P to D? You should feel the trans engage. If you don't, then you likely overheated and blew the trans when the engine overheated.
The 4Runner Show
