Originally Posted by blairracd
Bottom clip, because coils are advertised as 2.5”
1999 stock front coil springs are 1" taller than other model years so that's fairly accurate. 2.5" advertised minus 1" for being a 99. Move it up a clip or two. When springs settle they only get shorter not longer. Also, a lift only helps clear larger tires at ride height. If you articulate your front suspension (flex) the suspension still follows the same arc as before you lifted the front.
2000 SR5 V6 Manual 4WD
https://www.toyota-4runner.org/3rd-g...biography.html
