Originally Posted by atalarico
Ok, so I can get something like this steelie rim ( here) and just get a separate set of lugs that work with it?
I'm probably still going to go down an inch tire size so I can keep it inflated and clear the panhard bar, and then just air down the other three tires to match the size a little closer. 285/70s are usually less than 33" in diameter when measured new, and 275/70 are going to be over 32" by a bit, so the difference shouldn't be huge once aired down a bit. Plus, it's not like this is something I'm going to be driving on more than necessary to get home and get a new matching tire, etc.
But maybe I'm wrong, so I'm open to advice.
Slightly smaller will work in a pinch. If those steelies have a removable cap that can fit the stock metal tab through, they should work.
