Real Name: Jerod
Real Name: Jerod
If you don't have a torque wrench (good tool to start with though) tighten the idler pulley so that the tension of the A/C belt matches the power steering and alternator belts. Press on a floating section of the belt with your hand then on the A/C belt. If too tight, loosen the bolt a little, if too loose, tighten the bolt.
