Originally Posted by scotsman
I need to get new tires for my TRD Pro and I will admit I'm a bit of a poser in that it probably will never go off-road but I do like the appearance of a bigger tire. What do you recommend for that bigger look but not needing the ruggedness of say a KO2?
I would get a good street tire, but just bump it up a size from stock. You probably don't want any weight that you don't need. 275/70/17 will fit fine with no rubbing, but will give you the size you're after. Michelin defenders have been great on my wife's car.
This is assuming you're not dead set on an AT tire, even though you don't need it.
Build Thread
2015 SR5 Premium | SSO Slimline Bumper | 20" Heise LED Lightbar | 10K LB Smittybilt Winch | 285/70/17 | Shrockworks Sliders with Tread Plate | Toytec BOSS Aluma Series coilovers with 700 lb Coils | HD Superflex Rear Coils | SPC Upper Control Arms | Differential Drop | ARB Twin Compressor | CBI Ditch Light Brackets with Cheapo Amazon LED Cubes | UpTop Bravo Rack | RCI Skids
