Originally Posted by ncflyer
Haven't driven around with them but seem solid post mounting so far...
BD pros on caliraised low profile mounts. Other than the molding mod likely same way to mount under hood (verify the bolts are tight under the hood??)
If you did decide to change up, may not need to do this on the cbi since the mine were the low style mounts but to get more clearance at the back with the hood raised reverse the bracket so it pushes the light fwd a bit. Pros are slightly larger than the sports most seem to use.
Good luck
I want to say the squadron sports and pros are the same size. The XL's is where they start stepping up. I think.
Anyway, go drive that thing and let me know. lol
