Originally Posted by gamefreakgc
Trust your nose. Did you happen to re-use any injector o-rings or crush washers? They are all one-time use parts and re-using those seals can cause a fuel leak at the injectors.
Ironically, I took the injectors out JUST so I could replace the o-rings.... Should have just left them alone.. I don't recall seeing crush washers, though. I disconnected the fuel rail at the junction just above the fender well. I didn't mess with the banjo bolt at the end of the rail, if that's what you are referring to.
Last night was the first time I could get under the hood without rain. I was able to visually confirm that the middle injector on the passenger side is leaking up from the base.
Swapping out a rubber o-ring for another seems like a simple task. What could I have done wrong?
Mike.
