Originally Posted by CookieRoe
Thank you for clarifying that. After some thinking and seeing other countless Single Throw switch diagrams (pinouts), most have 2 "pins". To think that the switch itself has a ground is very silly. I thought that had some sort of a connection to the accessory (they don't). In the case of your NAV OVERRIDE, the unit itself has a ground. I can't wait to use it!
I tried the dimming feature by putting the switch ground wire to the white w/w green stripe right next to the green+ wire and the switch dimmed, I’ll have to redo mine since I like them to function as intended, not that I really use my dimmer much. The other white/green stripe didn’t dim, nor did the other white wire.
For the ground, I just had mine all grounded inside to the chassis together. My lights ground centrally under the hood and my relays under the hood together. As you know the switch doesn’t have to be attached to the ground wire all the way from the accessory to the switch inside.
My build thread https://www.toyota-4runner.org/4th-g...ml#post3520544
2008 Titanium Metallic 4WD 4Runner V6 SR5| Satoshi Grille mod|17x8 Level 8 MK6 wheels, 275/70/17" Falken Wildpeak tires| Front-Bilstein 5100's set at 0 with ToyTec branded Eibach silver springs and 1/2" ToyTec spacer driver side, 1/4" ToyTec spacer passenger|Front Diff. drop spacer kit|sway bar relocate kit| Rear-Fox 2.0Resi and ToyTec superflex black springs|Tyger Bull bar with LED's/Lund HX tube side steps
2021 Subaru Crosstrek Limited in Crystal White Pearl
