Originally Posted by tyrenta
I'm going your method -- I have some eastwood internal coating so will spray that but I'm going to blast anything internal with FF also
It will slow down and basically stop the rust. Just keep an close eye on things for a while. Hammer rot test is always a good method to find rotted areas..
Just the Eastwood internal coating or the rust inhibiting coating Eastwood coating. As it will work the best if super clean the inside frame out then use the rust inhibitor first then the internal frame coating. As if just the black spray paint you may with to save your time. ;)
Build Thread:
https://www.toyota-4runner.org/3rd-g...os-builds.html
Brillo's Bucket Fluid Ex changer:
https://www.toyota-4runner.org/3rd-g...ml#post3358086
Sparks Plugs Wire and Coil Information:
https://www.toyota-4runner.org/3rd-g...on-5vz-fe.html
