Originally Posted by Dom8706
Thank you for the response. Is there a guide to show me how to do this? Would I have to lossen all the body mounts or just a few of the back ones?
If I recall correctly there are three on each side between the tires, one on each side behind the rear tires and I assume one or two up front yeah?
search some of the body lift install threads here - that should give you the info you're after. I'd probably loosen them all then tighten the rears first when you get everything the way you want it if it were me.
keith
eimkeith.com
all product descriptions © eimkeith LLC 2016-2023
