Originally Posted by HimTiser
When I installed my 4x bumper, I just cut off the old bulb clip, and soldered the power and ground to the appropriate wires on the turn signal. I added in a waterproof connector as well in case the bumper needs to come off.
If your turn signals have the male blade connector, you can just buy the female blade ends from a hardware store, but I would recommend cutting those off and using solder and shrink wrap.
What do you think about those pre made shrink wraps with the wire connectors inside of the wrap itself? Would soldering them be more durable?
