Originally Posted by Bronc
I've had mine for about 2 weeks.
Pros: Easy to install, quality build and great storage. I was concerned that the top wing would not clear the JBL sub in the TRD Pro but there is about an inch of clearance.
Cons: Had an issue with squeeks, but a felt adhesive pad above the sliding drawer seems to have cured that. The MOLLE cutouts on the side of the box would be hard to access anything due to the top wings. I look at them more as a function for weight savings than extra storage. You will lose the accessibility of the storage area that holds your tire jack.
Overall, I would purchase again. Its a solid piece of kit.
Sent from my SM-T813 using Tapatalk
did you use the turnbuckles to install it ? I want to be able to remove it if needed and love not having to drill to install it, but I'm a little concerned about it shifting around especially off road
