phattyduck
mtbtim
weekendclimber
spartacus
theesotericone
midcoma
I think this has been said in pieces and part thru-out but...
My main motivation was:
1. Rust belt had destroyed almost everything about the drum brakes including the lines.
2. Rear seals leaking and soaking everything inside the drums so I needed to do rear seals anyways.
I have to do everything anyways... so why not disc brakes?
In true SleepyDad fashion I went wayyyyy overboard. I kind of wish I had not started the entire endeavor but... in the end I'm glad I have disc brakes that work almost as good as the toyota OEM even if I can't lock'um up.
Had I not done all the work already I would totally be in for this kit.
because I'm from MN... if you have not already watched VGG? do yourself a favor and sit down and give this fine gentleman a watch. if your a DIY wrencher then this guy is for you.
