Originally Posted by Quiero
I had Billsteins at the highest setting and 1" rear springs installed and had the truck aligned.
On the freeway it feels much floatier now. Like the wind is blowing it around when the wind is not blowing hard.
Still on factory tie rods and balljoints as well as bushings. In my older truck it drove similar to this before I replaced all of the front end components. Then again, I didnt notice this until the lift.
I've never owned a lifted vehicle. Is this normal?
Mine is the same way. Bought it this year with 154K mi. and was stock height. Put basically a 3”/2” on mine with 5100’s front and back and Eibach front springs and super flex rears. Right after I lifted it, it felt very floaty as well and that was with the exact same tires and wheels so I compared apples to apples. With new tires (bigger) and wheels it still felt exactly the same so it’s not my tires like some say. It felt pretty sketchy on the hwy or fwy and still kinds does.
I did replace the rear sway bar end links with Moog 2nd generation (1”longer than our 4th gen)
More Information for MOOG K80380 and energy poly bushings. This definitely helped some as it stiffened it up a bit and helped bring the rear geometry back a bit. After that, I did a sway bar relocate kit and drop as well as energy poly end link bushings and sway bar bushings. Didn’t notice much improvement in squirellyness there but feel the bumps more so may have helped a bit. It still floats and I know exactly what you mean. Not sure if somethings wrong with mine either. I just deal with it now and try to pay very close attention to the road, if not I have a tendency to end up on the other side pretty quick (happened just a few hours ago lol!
My build thread https://www.toyota-4runner.org/4th-g...ml#post3520544
2008 Titanium Metallic 4WD 4Runner V6 SR5| Satoshi Grille mod|17x8 Level 8 MK6 wheels, 275/70/17" Falken Wildpeak tires| Front-Bilstein 5100's set at 0 with ToyTec branded Eibach silver springs and 1/2" ToyTec spacer driver side, 1/4" ToyTec spacer passenger|Front Diff. drop spacer kit|sway bar relocate kit| Rear-Fox 2.0Resi and ToyTec superflex black springs|Tyger Bull bar with LED's/Lund HX tube side steps
2021 Subaru Crosstrek Limited in Crystal White Pearl
