Originally Posted by Utopia
So in running the numbers I am currently pulling a 1325lb trailer with approx 1000lbs of gear. The new enclosed is 2400lbs and will still have 1000lbs of year in it. So I am only adding about 1000lbs of weight that I am pulling.
You'll be fine in town pulling that weight. You already have the auto trans cooler on the front of the radiator so it should be a breeze to pull. If you experience too much rear sag, like previously mentioned, install some rear airbags like AirLift or Firestone.
