Originally Posted by ads2539
What temp is your thermostat set to? On my 4th gen, even if the heat/ac is off, there is still ~10% ventilation. If your thermostat is set to 80°, it will be hot in your 4Runner.
Is your wife hot also, or just you? The thermostat might also be set differently for the driver and passenger.
“That’s a beautiful housecoat you’re wearing today, Mrs. Cleaver!”
Yup my 2020 does same thing. Even with the heat controls shut off , a little heat still eminates from the vents and after driving around for 20 minutes, it gets warm inside ,plus the hot sun bearing down on you . I would adjusted the temp control to cold ....it helps.
