Originally Posted by waclo23
Hello, I am having trouble with my 4th Gen 4 runner not engaging into 4Hi.
When I switch into 4Hi, the indicator lights start flashing but nothing happens and the 4wd does not engage. When I switch it back into 2wd it makes a horrible grinding noise like missing a shift in a manual transmission and then the indicator lights turn off.
This has happened the last two times I have tried to use 4Hi and now there is a metallic rubbing noise while I am driving. Does anybody know what could be causing that rubbing noise?
2003 Toyota 4 Runner SR5 V6
Check if the front diff actuator is working... That grinding normally happens when you go from 4lo to 4hi without doing a complete stop when in neutral.
LC Prado 150
4th Gen 4Runner
1GR-FE
OME Springs w Bilstein 5100F&R, Durobumps bumb stops, Toytec 1" BL, Exhaust cam gears with 3° retard, Prado120 Snorkel, AFE Stage 2si, Magnaflow Catback w/ dual side exit 285/70R17 Dynapros MT Energy Suspension Bushings all around
