Originally Posted by spartacus
you can slide the compression clip off of the top radiator hose take the spark plug wire clips of the timing cover loosen the 12mm bolts slide the timing cover forward and check the belt you can also rotate the crank pulley bolt clockwise and check the belt.
This is what I would do. You can easily inspect the timing belt this way. Make sure the seal on the top part of the timing cover is good.
