Originally Posted by Inv4drZm
I would agree that a rear Toyota elocker is a pretty good and reliable option.
If you are eventually wanting a front locker, an ARB makes more sense, as you'll need the compressor and air components anyway.
If you can't find a used elocker diff, might try emailing ECGS and see if you can swap yours plus some money for their rebuilt elocker diffs. You could get it rebuilt with a solid pinion spacer at this time too. Not sure if they stock elocker motors or if you'll need to find one separately, those can be expensive.
Tacoma Elocker 3rd member
I'm looking into this since 8.2 axles aren't really that easy to find. Looks like assembled 8" rear elocker + front 8" reverse IFS clamshell with 4.56 gearing (and solid spacers front and rear) will run about $1400...then I'd have to source the elocker motor and a harness (no idea whether I'd need a high pinion or low pinion plug)...
Would all this simply bolt up and go?
