Originally Posted by Bad Luck
I'd fix the valve cover leak first, clean up the residual oil from the leak, and drive it for a while before deciding on the rear main leak. You may discover that it isn't leaking enough to repair it. Or at least save it for down the line. Just my $0.02
Sounds good.
2000 Toyota 4Runner V6 3.4L Valve Cover Gasket Set
Would this kit suffice? Says OEM
