View Single Post
Old 05-29-2020, 08:50 AM
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Originally Posted by da_crew10 View Post
Actually pieces it together cheaper from the same place I ordered my lbj.
Can someone chime in and see if I ordered correctly
Part# 1121360202 x2 valve cover gaskets
Part# 1119370100 spark plug seal x 6
P.s just cleaned up under the tranny area. I dont think it's my rear main seal. Leak comes from way up above most likely the valve cover gaskets and half noon things . Yall are some o.gs knowing all this lol.
I'm doing most of everything myself. But a rear main seal job would be something I wouldn't do due to time and tools.
You'll also need FIPG, camshaft plugs, and either clean the half moons or replace them. I chose to replace them. It's also a good idea to order all the valve cover bolt grommets as well.
I ordered:
11213-62020 (x2) Valve Cover Gasket
11193-70010 (x6) Valve Cover Gasket (spark plug tube gasket)
17176-62040 (x2) Plenum Gasket
90210-05007 (x16) Washer Seal
11188-62010 (x2) Plug
11183-62010 (x4) Plug Semicircular
00295-00103 Trans Pan Sealer/Valve Cover FIPG
12204-62010 PCV Valve
90480-18001 Grommet
