View Single Post
Old 05-29-2020, 02:19 PM
beklemmung's Avatar
beklemmung beklemmung is offline
Real Name: Levi
beklemmung is on a distinguished road
beklemmung's Avatar
Real Name: Levi
Originally Posted by Bad Luck View Post
You'll also need FIPG, camshaft plugs, and either clean the half moons or replace them. I chose to replace them. It's also a good idea to order all the valve cover grommets as well.
I ordered:
11213-62020 (x2) Valve Cover Gasket
11193-70010 (x6) Valve Cover Gasket (spark plug tube gasket)
17176-62040 (x2) Plenum Gasket
90210-05007 (x16) Washer Seal
11188-62010 (x2) Plug
11183-62010 (x4) Plug Semicircular
00295-00103 Trans Pan Sealer/Valve Cover FIPG
12204-62010 PCV Valve
90480-18001 Grommet
I don't mean to derail this too much, but since I'm preparing to deal with leaking VCGs myself, is it typical to replace spark plugs and spark plug wires (19037-62050) when doing this work? And the throttle body gasket (22271-62040)?
1997 3.4L 4WD auto SR5, nearly 200k miles, pretty much all stock
beklemmung is offline   Reply With QuoteReply With Quote
