Originally Posted by Y2K-4runner
My 4runner has the 2 cat system. I'm guessing it was set up for CA even though it was bought here in PA. Anyways, rust has destroyed the flanges and I've had the code for the front sensor for a while. It is a spare vehicle that's been sitting and needs the safety inspection done. Rockauto appears to have 2 different sets of CATs for it. One set is C. A. R. B. and the other isn't. They lower prices ones are made by Eastern. Since I don't live in CA, do I need to still bolt on the C. A. R. B. units? Will it cause problems if I get the non-CA compliant? They cost quite a bit more. I plan on buying the Denso sensor since the rear worked out good. Thanks!
Originally Posted by phattyduck
The pipes between the non-CARB and CARB cat systems are mechanically different. Is the non-CARB approved option you are considering meant to bolt in place of the CARB system?
You do not need the CARB cats unless you are planning to smog your vehicle in CA. You run just about any cat that will fit/weld in place without a CARB certification.
CARB cats do not have different pipes only a CARB Executive order stamped/etched certification on the cat and a (California) premium price that is required by the smog technician to input for smog.
I replaced my cats with Magnaflow CARB certified and verified with MF that there is no difference in build other that the certification. Hope this helps.
