So.........none of the Tundra bushings fit. I don’t know what folks are doing. If you buy new top hats but then try and use the bushing supplied with the Tundra billsteins it won’t fit into the top hat to keep the shock shaft centered.
Best guess I can make is that the center hole in the Tundra top hat is larger.
I drilled my top hats out to 22/32 so that now the Nolathane and billstein bushings fit properly and keep the shaft centered.
Owned 82, 83, 87 pickup, 98, 99 SR5 4runner
Currently own a 98 SR5, 5spd, 4x4, e-locker, no sunroof. 2012 LTD with the normal options.
