Originally Posted by Run Forrest Run
Great info- this is a great reference.
Did you use comfort, performance or constant load coils?
Our starting heights are the same except I am 3/8” low on drivers front (lean)- had you compensated for that previously?
Your FCP shocks are adjustable, did you set them to factory recommended height to start??
I assume you will settle in the front or you can always adjust down.
Photos look great- thanks so much for the info!
I went with Performance Springs. I set the driver side 1/4" higher in the front to compensate for the lean. The rear I have a slight lean as well. Ironman recommended a measurement and that is where I started at.
2016 T4R SR5: Ironman FCP w/ Performance Springs l RAV4 Mirrors l TSO Pro Grill l TSO INCOG Front Bumper l Raptor Lights l 255/80 Falken WildPeak AT3W l CaliRaisedLED Ditch Light Brackets l Avid Sliders l Custom Drawers l R1 Concepts Rotors/Pads
5th Gen Build
1996 T4R Limited: E-Locked l 285 KO2's l Toytec BOSS w Superflex l SS Panhard l Ultra Gauge l AIRAID MIT l Drifter CB Mount l AOF Sliders l Weathertech's l Hilux 167 Snorke l Cobra 19DXIV l Ditch Lights l Relentless Front Bumper l Superwinch Tiger Shark l Paranoid Fab Din Switch
