Originally Posted by phattyduck
Looking good. Hopefully you scrubbed that arm rest/handle before you re-installed it. They clean up pretty easily...
If the tie rods are tight, no need to replace them (not a safety issue like the LBJ). Also, if you think there is any chance you need a new steering rack, the OEM one comes with new ITR's, and makes it a good deal compared to questionable aftermarket options.
Would love to know what your process was for scrubbing the armrest fabric as I have tried on both doors with no success. Maybe the fabric/material on the Sport package is more difficult to clean than others but please share any suggestions.
Steering rack seems ok but there is minimal play in the front end so thought tie rod ends may help.
LBJ’s were replaced under recall at 60K but now have 180K so figured it was due for another set. I see they have the plastic protectors on them so thinking that means the lower torque numbers when I replace the LBJ as well as the 4 bolts each side......correct?
