I would use a mirror and a flashlight to look under the crank pulley. You should be able to see if its leaking from the front main seal or if it is the pan.
Personally, I'd rather do a timing belt job and replace the seal than drop the front diff and screw with the oil pan. The seal is very easy to replace but you do have to take a bunch of crap off to get to it.
If it is the pan that is leaking, you could try re-torquing the pan bolts in that area. Maybe they are just a little loose.
1999 SR5 4x4 Auto for parts
2011 Camry SE V6
2011 Highlander Limited
