Originally Posted by phattyduck
You should probably be running 30-35psi on the street - though that is dependent on tire and load.
Ya I thought 40 might have been too high, I guess I'll try out the chalk test that was suggested with some lower PSI. Ill try to progressively go down below 25 next time I hit a trail. I still have the stock wheels and I'm using Toyo M/T 255/85R16. What would you say is too low PSI? I don't want to have to try fitting a tire on the wheels when I'm on a trail.
Thanks
