I would look into the 99 tall coils and some oem or equivalent shocks, that should give you the 1" over stock you're looking for and keep the ride nice. I would consider doing lower ball joints while you're at it, oem only on those.
your bushings are likely still good since you have pretty low miles, if you do decide to replace them I would use oem, those will ride the best, I run poly everything but it gives a much firmer ride.
someone who did the 99 spring upgrade can probably direct you towards a kit or link to source for the parts
