Originally Posted by Jetboy
It's definitely not tire related. I'm pretty sure I've put a lot more stress on my end links than you'd get from just having a stiffer tire. I've taken mine out jumping in the desert. Rock crawling. Etc. I've even bent the rear fixed link by dropping it onto a big rock. Bushings are still good at 50k. The only think I've noticed is that the metal straps that are supposed to help hold the bushings on have come off. But other than that - no issues. The folks who are running 20" wheels with lower profile tires have harsher ride than putting on E rated 17" tires. So for example all of the GX's will have firmer tire/wheel combos than an E rated 265/70/17.
Same here on the metal strap.
Regarding those in the Gulf States where Toyota doesn't stock KDSS (you have to order one if you want one) you may be better going to a Lexus dealership since GX's all have KDSS and mechanics should know how to work on them.
2017 Off-road Premium w KDSS, moon roof, sliding rear cargo deck,3" Toytech Boss lift, SPC upper control arms, Sonoran Steel High Articulation KDSS Trac/PanHard Bar, RCI sliders, RCI skid plates aluminum including gas tank, C4 Fab diff skid plate, SCS Ray 10 Wheels Matte Gray, 285/70R17 Hankook Dynapro AT2 RF11 E-load RWL, Cali Raised LED 3x2 fog-light pods, Lock'r Down EXxtreme console safe with electronic lock, Auto Heat Shield all windows, Raingler rear cargo net, Canvasback rear covers, LFD Off-Road cross bars aluminum, LFD Hybrid bumper, LFD wind fairing, LFD Hi-lift jack mounts, Goat Armor, Blackgate Custom KDSS spacers, Ironman 2.5 awning with quick release mounts, Ironman 12,000 lb synthetic line winch.
